I have Nitecore UM2 (2 slot) battery charger whose current sense/shunt resistor of 0.1 ohms R100 (package 1206) blown. I replaced with working slot to see if everything works good and it is.
I am looking to replace this R100 (0.1 ohm) with R005 (0.05 ohms) shunt resistor. I have two of them found on dead laptop BMS. One BMS had three 18650 in series and another had four 18650.
I use this charger to charge Nimh and 18650 batteries. Charger can output 1A max/cell (adjustable). So 4.2v 1A max is what is going to transfer from this shunt.
The two R005 shunt resistor I have are 1206 and 2512 package. And the question is can I use this shunt in replacement of R100? If yes which package? Will there be an issue with charger providing accurate CC i adjust it to?
I have no idea about this so I had to ask. I searched on the internet already but found nothing.
