I am struggling to get an acknowledge from the MPU6050 using ESP32 with Arduino framework. I am unable to derive if the problem is hardware or firmware.
I have copied Sparkfun's breakout board schematic, setting the FSYNC, CLKIN and AD0 pins to GND and SDA, SCL and INT to GPIOs 25, 26 and 27 respectively (INT is unused/floating). I am using 2.7 kΩ pull-ups for the I2C lines.
I am using the following code to test the I2C comms:
#include <Wire.h>
#define I2C_SDA 25
#define I2C_SCL 26
void setup() {
Wire.setClock(100000UL);
Wire.begin(I2C_SDA, I2C_SCL);
delay(3000);
Serial.begin(115200);
Serial.println("\nI2C Scanner");
void loop() {
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ ) {
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0) {
Serial.print("I2C device found at address 0x");
if (address<16) {
Serial.print("0");
Serial.println(address,HEX);
nDevices++;
else if (error==4) {
Serial.print("Unknow error at address 0x");
if (address<16) {
Serial.print("0");
if (nDevices == 0) {
Serial.println("No I2C devices found\n");
else {
Serial.println("done\n");
delay(5000);
I have probed the I2C line using a logic analyser. The code behaves as expected but I get no acknowledge.
I have checked that the chip has power, lowered the speed from 200 kHz (default) to 100 kHz. I have tried using internal pull-ups on ESP32 instead of external. I have tried a different MPU6050 chip.
Any help diagnosing would be greatly appreciated.
