I know this problem has been discussed numerous times, however I cannot find the solution.
I am using Altium "Manufacturer part search" to download schematic symbols and footprints, which are then added to project via "Add existing to project...". In the window that pops up, I choose to add schematic and PCB library files, leaving the "altium integrated library" file unselected. From there I modify some of the schematic symbols (if needed), and leave others unmodified. Then I place the schematic symbol into my schematic document. In such manner I have designed all my schematic files.
The problem appears when I want to import changes into my newly created PCB document. Here I receive errors that say "Unkown pin: Pin .... ". Every single component, that was added by downloading schematics and footprints from "Manufacturer part search" has this error, doesn't matter if I modified it or not.
I have managed to fix one such error by replacing the schematic symbol and rewiring the connection (this had to be repeated multiple times to work) in schematic file. However, this does not work on other places.
I have tried restarting Altium, restarting the PC. Footprint designators match the schematic symbols. When in schematic, in parameter view, I can see the assigned footprint to the schematic symbol.
I have no idea what is happening. Please, help.
Adding messages window:
