I simulated a half bridge with two NMOS and at every switching event a current spike up to 1.2 A in the voltage source V4 occurs. I used a resistor as load because with any inductive or capacitive load I would expect a spike because of the dead time between the MOSFETs. Can the parastitic capacitance between Gate-Drain and Gate-Source be the reason or did I do something wrong in the simulation? I know that the selected FETs are oversized but properly I need them for a higher load.
Schematic:
M1 Vsource Vg_HS Vnode Vnode IXFX90N30
M2 Vnode Vg_LS 0 0 IXFX90N30
V4 Vsource 0 100
R3 0 Vnode 1k
V1 Vg_HS Vnode PWL REPEAT FOREVER (0 5 0.00159999 5 0.0016 0 0.0033 0 0.0033000001 5) ENDREPEAT
V2 Vg_LS 0 PWL REPEAT FOREVER (0 0 0.001649999 0 0.00165 5 0.003249999 5 0.00325 0 0.0033 0) ENDREPEAT
.model NMOS NMOS
.model PMOS PMOS
.lib C:\Users\hamsn\Documents\LTspiceXVII\lib\cmp\standard.mos
.tran 7m
.backanno
.end
