I have this circuit which is part of a bigger schematic used for capacitance measurement. This circuit should output 7.5V as the opamp is configured as a repeater and the input voltage is 7.5V (15V divided by 2).
I don't exactly know the role of R3 and why its value is 500kohm.
D2 is one of the 2 back-to-back diodes that are placed in the real design.
The problem is that if I short D2 the output goes up to 13V and stays there even if I remove the short from D2. The circuit enters this state even if I randomly touch R3 or D2 using tweezers or even finger, not necessarily shorting D2. The output reverts to the normal state if I briefly short one of the inputs to the ground.
I implemented the below schematic on a breadboard to try to replicate the issue and I did it, the issue is still there so it's not influenced by other circuits on my board.
I also have some older boards with the same design and same opamp part number, but a different batch I guess .... the problem started appearing some weeks ago and I didn't have this problem before, 90% of my boards have this issue now.
- If I remove D2 the problem disappears
- If I replace the opamp with an older one but same part number the problem disappears
- If I replace R3 with 100kohm the problem disappears
