I am trying to repair an Xbox Series X after a liquid damage and I found a short in the B2B connector. I need to replace it, but after lots a research, I can't find the reference online.
Here is the reference from the schematics: M1094507-001. I am not sure if the schematics version is the good one, so this reference might not correspond to the pictures. This connector has 80 pins in the first row and is SMD soldered.
Here are pictures from both connector and ribbon cable:
Edit: Here are some additional details to help us find this connector. If we have trouble finding it, it should also be the case for other people.
This ribbon cable is the same at both ends, as you can see on the following pictures. The pitch it 0.5 mm @Lundin. To me the number of position is 80 since the ribbon cable has only one side.
I looked for 1X80RCPT_40MHZ reference but nothing for the moment. I am going to search in Semtech catalog and I will keep you informed.
