Can you identify these ST brand SMD components? They're from a angle decoder circuit with LEDs and relays.
1 Answer
Used the The ultimate SMD marking codes database:
- Marking code
BEX
: Used by several manufacturers. SM15T39CA from SGS-Thomson Microelectronics. datasheet confirms the marking. - Marking code
MEM
: Used by several manufacturers. SM15T24A from SGS-Thomson Microelectronics. datasheet confirms the marking. - Marking code
MEP
: SM15T27A from SGS-Thomson Microelectronics. datasheet (same as for SM15T24A) confirms the marking.
\$\begingroup\$ Thank you so much you're the best! \$\endgroup\$ Commented Oct 5, 2023 at 10:11
