Can anyone identify this 8-pin DFN SMD component?
Marking is:
LAAS
N819
417
  • \$\begingroup\$ That's DFN, not QFN. \$\endgroup\$
    – Hearth
    Commented Dec 8, 2023 at 15:10
  • \$\begingroup\$ From what device/module did you get it? \$\endgroup\$
    – liaifat85
    Commented Dec 8, 2023 at 15:45
    \$\begingroup\$ Components around it may provide clues so please post a wider shot \$\endgroup\$
    – bobflux
    Commented Dec 8, 2023 at 17:00
    \$\begingroup\$ Diana - Hi, You posted an answer to say thank you. Although that's polite, Stack Exchange has different rules from typical forums (please see the tour & help center). An answer cannot be used in that way, so it was deleted (and moved to a comment, at least temporarily). Please see the article in the help center called: "What should I do when someone answers my question?". If your question has been solved, consider upvoting useful answers & consider áccepting your choice of best answer, when you're sure it answers your question. Thanks. \$\endgroup\$
    – SamGibson
    Commented Dec 11, 2023 at 5:14
Possibly Analog Devices LTC1540.
The LTC1540 is an 8-pin DFN package, size 3x3mm. The datasheet indicates the first line of the marking should be LAAS:
Pin Configuration and Marking from Datasheet
With no further details about what the circuit does and he surrounding components and dimensions, this is purely a best guess.
It seems promising as pins 1 and 2 (V- and GND) appear to go to a large plane from your image, and pin 7 (V+) goes to a thick trace which could be a power feed.
  • \$\begingroup\$ Pin n°1 marking is typical of Linear Tech (Analog devices) +1 \$\endgroup\$
    – vivier
    Commented Dec 9, 2023 at 20:17
    \$\begingroup\$ Wow thanks for the suggestion. Looks matching base on marking. Will still verify the connections. Thanks alot! It was a great help =) \$\endgroup\$
    – Diana
    Commented Dec 11, 2023 at 4:52
