I'm looking for help with my NFC (13.56MHz) antenna design. I am using a NXP-NT3H2111 NFC IC and so far I have read through the application note and other research papers available online to try design an NFC antenna. I'm not sure about how to verify the functionality of my antenna before fabrication (i.e. in HFSS ) generally, for an antenna we measure parameters such as S11; Rad-pattern but I have no clue regarding the parameter constraints for a NFC antenna. These are my design parameters, the main reason for choosing the following parameters is because this dimension falls under class 6 antenna category in NFC.
This image is my NFC antenna design, I have made use of the tool provided by NXP to calculate the dimensions and other values but I am not sure about verifying the functionality in HFSS. I tried measuring the S11 but there was no dip in at the desired frequency & even at the self-resonance frequency of the antenna there was no changes in the S11 plot.
I am really confused about how to proceed further, I dont think there are any geometrical errors in my design but I do have a strong feeling that I may have made some mistake when it comes to simulating the antenna ( giving wrong excitation and such things ) I would be grateful if anyone of you can point me in the right direction.
