We are attempting to electrically connect an SMA connector to two pieces of stainless steel to measure the capacitance between them for a school project.
In the picture below, you can see the two pieces of stainless steel, grey and blue, respectively, with a red insulator between them. The outer barrel of the SMA connector simply screws down to Stainless 1. However, the inner conductor can't simply connect to Stainless 2.
We have considered directly soldering the inner conductor to Stainless 2 using a wire and a blowtorch or machining some type of plug/outlet, but it isn't elegant. We are also worried about contact resistance introducing noise to our measurements. Have we missed any ideal way to interface these conductors?
Note: It's possible to reduce the thickness of Stainless 1 or add material to Stainless 2 if needed. The parts haven't been machined yet.
