Can anyone identify this coax connector? I think it might be an SMA female connector but I'm no expert. It has threads on the outside and a hole inside. The diameter (to the outside of the threads) is 5.25 mm. The pink ruler in the first picture is in cm. The yellow tape measure in the second picture is in inches.
The connector is on a shaker that I need to connect to an amplifier. The cable that connects them is missing, so I'm going to get a custom one. The other end of the cable will have a dual banana plug. Is there a particular type of cable I should use in this application?
UPDATE: it's not SMA. Or SMB, for that matter; I took it to a hardware store yesterday and tried both. They didn't have any SSMA or SMC for me to try, though, so I suppose it could be one of those...
