I am doing a project to use dsPIC as controller to output PWM signal to control motors. I can use driver IC (I used L293D actually) to simply let motors to rotate, but I cannot control the voltage range to control the motor to rotate with all range of speed.
The output of dsPIC PWM pins is in the range of 0V~5V, but for motors, the input range is different.
Assume the range is -10V~10V, I want to change the 0~5V output to -10V~10V (0V->-10V, 5V->10V). Is there a good way to achieve this?
