I have these devices:
- Sensor Keyence FS-N41P
- Camera Flir Blackfly S
- Controller Teknic Clearcore
The sensor triggers the camera and the controller. The controller supplies 24V to the sensor.
This is a schematic that works. I also added some technical details from the manuals: Download KiCad Schematics
Some more info for the camera:
My big question is: Am i missing something or is something wrong?
- I am not sure if the pull-up/down resistors are correct?
- The camera opto out is open drain and requires a pullup resistor. The controller input seems to have a internal 5k pullup to 5V. The camera manual recommends 1k pullup for 5V. Is this a problem?
- Camera opto out is described as "open drain". Do i need another resistor like in the Clearcore "Digital PNP" example? Is this a pulldown? Can you have a internal pullup and an external pulldown at the same time?
