Using a microcontroller timer, is it possible to produce the following signals:
With the following constraints:
- use only one timer (can count up or down or up and down)
- output compare channel has only one comparison register
- no software interactions after the initial setup
I don't want to couple the question to any particular MCU, but you can think of STM32 timers as an example.
I would say it is not possible, but maybe I am not seeing some clever register configuration.
