I'm doing a noise simulation of a transimpedance amplifier (TIA) in LTSpice for calculating the total RMS noise. The bandwidth is approximately 100 kHz. As long as the simulation stop frequency is higher than the bandwidth of the circuit I get, as expected, the same value of the RMS noise.
Now to the actual question - if I have a delta-sigma ADC with a 100 Hz digital lowpass filter sampling the output of the TIA, can I simply set the stop frequency in the simulation to 100 Hz to get a reasonably good approximation of the RMS noise of the sampled and digitally filtered signal?
