A common 2nd order Delta Sigma ADC topology is shown for example in Wikipedia. Here, if you omit the left summing node and the left Integrator, a conventional 1st order Delta Sigma ADC emerges.
Now consider the following implementation of a 1st order Delta Sigma converter:
The three left components (R10, R11, C6) realize the summing and integration function. The comparator and its positive feedback branch realize the Quantizer and DAC functions. This works nicely and I have used it many times.
I now attempted to extend this architecture to realize a 2nd order modulator, by adding another summing and integration node:
The feedback resistors have been set to ensure a signal transfer gain of 1, and the integration capacitors have been set to obtain a similar switching frequency.
The PWM waveform that comes out of this supposedly 2nd order modulator looks almost exactly like the one from the previous 1st order modulator. The typical features of a 2nd order modulator are missing, such as double pulses or in general a seemingly non-constant duty cycle. Below is an example of the output of the first and second schematic, which are nearly identical apart from a minor frequency difference.
And, finally, here is the spectra of the two outputs, while modulating the same input, which is a 50 kHz, 0 dBV sine wave. Both versions show a roughly 20 dB/dec noise increase towards the natural modulator frequency. The flat part of the noise at low frequencies is an artifact from the resampling that LTspice does in order to compute the DFT, I guess.
Why isn't this behaving as a 2nd order Delta Sigma modulator?
