I'm making a VCO for use as a module in a synth. The oscillator part is working fine. I also need to translate a 1v/oct voltage input to a log scaled voltage output in order to get the correct freq out of the VCO. Makes sense. So I built a lin to log circuit as well (2 opamps tied together with emitter), which also works fine. enter image description here
I did some testing with my signalgen and fed the VCO to see what voltage is needed for certain freqs.
In the column V from keyboard is the ideal voltage coming from my keyboard (which in reality gives a 0-5v output). The column V to VCO is the actual voltage needed (as tested with my signalgen) resulting in the correct freqs.
The 2 combined though (OSC and LIN2LOG circuit) dont match up (surprise surprise. I dont want it to be correct over the whole musical range; a normal expected behaviour for a VCO would be 2-3 octave of correct sounding octaves and a pitch knob to set the base freq. Im totally ok with that.
My assumptions: lin to log conversion is what it is. I cannot control the slope (because of the behaviour of the transistors) so I have to focus on the input of things. My idea is to 'scale' the input in such a way that the output curve of the LIN2LOG circuit behaves like my graph.
My question is the following: Am I on the right track here? What is the best place to start looking for the solution? Trying to learn here :-)
  • \$\begingroup\$ I don't see the conversion factor needed between the VCO voltage and the LIN2LOG voltage. \$\endgroup\$ Commented Nov 2 at 16:41
You are mostly on the right track.
The log() circuit will generate an output exponentially dependent on VIN/26mV. Thus for each 26 mV increase in VIN, the output signal will change by a factor of e (2.718). Equivalently, each 18 mV increase in VIN will double the output (e.g. 1 octave), and a 60 mV increase will increase the output 10x.
Your VCO is not particularly linear (V to F is not linear). It is not clear what different transfer function you need.
You might find that using a small MCU (Arduino) with an ADC and DAC is the easiest way to implement any transfer function you want.
  • \$\begingroup\$ Where does VIN/26mV come from? Is that number based on the numbers I supplied or is it a given 'fact' because I use transistors and thats just part of their behaviour? \$\endgroup\$ Commented Nov 2 at 22:40
    \$\begingroup\$ It's fundamental to the operation of BJTs (at room temperature). The collector current is ISexp(qVBE/kT - 1). kT/q is 26 mV at room temperature. IS will vary device to device, but the rest of the equation is fairly inviolable. \$\endgroup\$
    – jp314
    Commented Nov 3 at 1:58
  • \$\begingroup\$ @jp314 - And the exponential dependence on temperature gives some insight into why monolithic differential amps, where two transistors are physically adjacent on a chip, has had a very large impact on analog circuit design. Adjacent transistors on a chip are far better matched, both thermally and in terma of gain, than is possible for discrete parts. \$\endgroup\$ Commented Nov 3 at 4:13
