I am using the LP38693SD-3.3/NOPB (datasheet) power converter to step down +5V to +3.3V. I used the WEBENCH power designer tool from TI for the schematic and I chose the input and output capacitors based on the recommendations from the datasheet. My questions are as follows:
Will I run into problems if I connect EN pin to Vin pin through a resistor? Again, this schematic was generated by the WEBENCH power designer tool from TI, but in the datasheet even though it says under 8.3.1 Enable (EN) "If the application does not require the Enable function, the pin must be connected directly to the IN pin." just a little further down under 8.3.3 Foldback Current Limiting it's a CAUTION which I don't really understand(see screenshot bellow).
Did I choose the input and output capacitors correctly? In the datasheet it says that the output capacitor needs to have an ESR between 5-500 mΩ. The issue with the capacitor recommended by TI in the BOM list is that it has an ESR of only 1 mΩ, so it doesn't respect the recommendations from the datasheet. Since the input capacitor doesn't have any requirements when it comes to ESR or capacitance (it only needs to be at least 1uF and no more that 10 µF because I am using an USB port at the input of the power converter), I chose the same capacitor(GRM31CR71H475KA12K datasheet) for the input and output. The capacitor has a minimum of 5 mΩ at ~2 MHz(see screenshot below), but from my understanding if the frequency is not specified in the datasheet of the power converter where it talks about the ESR of the output capacitor, we should assume a frequency of ~100 kHz to max 1 MHz, so this capacitor should be well suited for the output. Also it has pretty good DC bias and temp characteristics(see screenshots below).
Does the EP pin refer to the 'exposed pad' and should it be connected to GND? I couldn't find any reference to this pin in the datasheet.
My schematic:
TI's recommended schematic:
Caution:
ESR of the capacitor:
DC bias characteristics:
Temperature characteristics:
