I often see those phrases in tutorials with microcontroller I/O. An example use is "set pin 3 high", or "set pin 5 low for 20 ms".
I also recall reading several different definitions on what that terminology means. Does the low in "set low" mean low impedance? Does it mean low logic level (0 volts)? Or does it mean low as in negative voltage? Or is there even a universal meaning for those phrases?
