I have a basic circuit: battery, fuse off (+)lead, 4 lights in parallel.
My question is, when charging is a fuse needed?
Also in the battery/charger circuit, which side is considered positive?
Update:
Ive obtained a 2amp glass fuse, as recommended, but it is a high voltage fuse. Checking the voltage off the plugged-in charger(12V/1AMP), with its 2amp high-voltage glass fuse on, reads at 14.5V.
I attach the charger to a 12V battery, which has a 10amp blade-type low-voltage fuse, off the positive cathode.
The charging light doesn't come on when connected; however the charged-complete led came on when I it was being checked with the voltmeter.
here is my system:
charger + fuse: a weather-proof connector between battery and charger: the battery with text: top of battery can see fuse off cathode and a quick-connector type:
