I have tried EVERYTHING to make this work, including replacing the board.
I have an arduino fio
I am attempting to upload a sketch to it (just a blink to validate it works) with an FTDI to USB cable
I am using Arduino 1.5 BETA and I also tried Arduino 1.0.5 Neither of which worked and resulted in the same error.
I attempted to use a different comp with a fresh install that resulted in the same error.
I updated my FTDI driver to 2.0.8.30 still the same error
I dismantled the FTDI wire and re-soldered it to new wires to verify it wasn't a bad connection.
I attempted setting the baud rate in device manager to 9600,57600, and 115200
I tried pressing the reset button as I uploaded the sketch
I tried changing COMS
I tried plugging an Arduino Uno in, validating that it works no problem. Then I plugged the fio back in. Got the same error again same error.
This is the second board I have gotten that does this. It's not the board. What the hell is wrong with this software. I shouldn't have to work this hard to upload a freaking sketch.
IDE output
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino/hardware/tools/avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done. Thank you.
And yes, I have tried restarting both the IDE and the computer(s).
