I'm looking for a little help understanding this circuit:
http://i1316.photobucket.com/albums/t607/blueturnsred1/Capture_zps5150bde6.jpg
Details of the circuit:
1 IRF510 Power MOSFET N-Channel
1 1M Ohm Resistor
The sensor is made from plaster of paris
About the circuit:
Basically what we have is a mosfet connected to an LED and a 6 volt solar cell. The sensor is a piece of plaster of paris with two nails in it. The whole kit can be seen here:
http://technologywillsaveus.org/resources/thirsty-plant/
The idea behind the circuit is that you put it in a plant's soil, and when the plaster of paris "sensor" dries out the led comes on, and you know it's time to water the plant.
I have been trying to wrap my head around how this switch works. What I have been able to understand so far is that in a typical switching application. when five volts is applied to the gate of the the MOSFET it will switch on and allow the circuit to function.
The way I think that this circuit works is that the current is shorted through the "sensor" when the plaster of paris is wet. I believe this keeps the current from going to the gate of the MOSFET, and keeps the LED off. Then when the "sensor" dries out the current goes to the gate and switches the MOSFET on.
Can anyone tell me if I am on the right track?
I have read a lot of tutorials, but I can't find anything that will help me further understand this.
