I'm looking for a board mount (IC) solution that will take the differential output of something like ONET1191 @10GHz and convert it to 50 or even 75 Ohm single ended.
I've looked through various suppliers for:
- Baluns (and other transformer solutions)
- Differential Amplifiers
- Receivers/Transceivers
However, I can not seem to find any modules with a pass band around 10GHz. I see tons and tons of ~6GHz modules (makes sense because 1080p60).
Alternatively, I could simply pass it out through 100 Ohm twinax and into a discrete RF amp that takes differential input (those do exist, but they are expensive!!!). I am hoping to avoid this, due to cost reasons.
Just throwing this out into the wind to catch some useful suggestions, thanks!
