The bandwidth of electronic parts, like analog switches, is usually specified for a specific load, typically 50 ohm and 5 pF for example.
Now if I have an analog switch with a bandwidth of 1 GHz for a 50 ohm load, how the bandwidth change depending on the load? What appends for, say, a load of 1 kOhm? Is there a way to calculate or estimate the bandwidth for different load values?
Thanks.
(this is a follow-up of High voltage high bandwidth analog mux)
