GEKO diesel generator has 60 kVA electric power. Our switch mode power supply connected to this generator via passive filter DL-50EA3 and 6-pulse bridge rectifier (see the schematic). In this configuration we suffering from the filter excitation:
(yellow - input voltage divided by 10 = 200V/div, blue - current 5Amps/Volt = 25A/div)
If the power supply connected to the regular electric network - everything is OK.
Schematic:
The equipment connected to the generator suffers from this parasitic oscillation and we need to suppress it as we can.
One possible solution is to put additional filter between generator and rest equipment in the following configuration:
Can anyone suggest the filter? Or maybe we miss some extra solution.
