Hi,
So the trouble I am having with this problem is that I don't know how to do nodal analysis with the dependent source. I would normally just do a source transformation and change the current source to a voltage source and then just do KVL's. But since the dependent source is reliant on Vo, I don't know how to solve it using Nodal Analysis. Vo is the voltage across R2.
Thanks
Voltage at the node where R2 is connected is Vo, consider voltage at other node is \$V_1\$ By KCL:
$$\frac{V_o}{R_2} + \frac{V_o-V_1}{R_1} + \frac{V_o-V_2-2V_o}{R_3} = 0$$
To find \$V_2\$ here it is simply \$R_4 \cdot I_1 = 48V\$.
Now put the values and you will get your answer.
However you can do same using the loop analysis and KVL.
The thing is keep the dependent source variable as it is and just solve as you normally do.
  • \$\begingroup\$ Use some markup on those numbers and you have my +1. \$\endgroup\$
    – Dzarda
    Sep 2, 2014 at 15:53
    \$\begingroup\$ There seems to be an error here. V2 (voltage at the top of I1) can't be 48V. Please check. \$\endgroup\$ Sep 3, 2014 at 6:54
