Beginner question, but at least my Google skills didn't yield any results. Why do some capacitors have 5 terminals? Such as this one
What are they used for?
Check out this data sheet of the Vishay capacitors that look alike the one you showed. It seems the extra pins are for mounting, since it's a big capacitor.
This could very well be multiple capacitors in one package, probably with a shared negative (-). The legend states "1 = 220 uF". Are there also markings like "2 = xyz uF", and are the connections by any chance marked -, 1, 2, etc?
For completeness, motor "capacitors" are often more than one actual capacitor bundled into a single package, and thus have more than two leads. A very common example is the start/run capacitor usually found in air-conditioning units.
I don't think your image is one of these though.
