I'm building an analog switching circuit which is controlled by an arduino.
My circuit requires 25 4066 quad-analog switches.
To get the required analog voltage range for the switched inputs, I need to provide +5v and -5v input power to all 25 of the 4066's.
I have tried to use a 1044 charge pump to get -5v, but it can't power more than one 4066, it seems. I only tried the std. 1044 circuit as provided in the data sheet.
I also need to be able to provide switch control voltage of +5v and -5v to the 4066s to turn on and off the switches. I am not sure that the Arduino pin's LOW output of 0v will be low enough to completely switch OFF the 4066 in the negative part of the analog signal.
Could anyone help me by providing an idea for a circuit that do all that, or maybe suggest a way forward?
Thanks so much,
Bob
