In the circuit below, Vs=18V, R1=100Ω, R2=100Ω, R3=100Ω, and R4=100Ω.! Determine RTh for the Thévenin equivalent circuit.
I know to find the thevenin resistance, all independent voltage sources are converted to shorts and current sources are converted to open circuits.
In the diagram above, if the circuit is if the voltage source is replaced with a short, then R1 // R2. My confusion is in part II of the diagram. I thought in part II of the simplified circuit, it doesn't matter how the final circuit is decomposed--but apparently it does. When I simply for the circuit as I did in green, I get the correct solution, but in the the blue ink, its incorrect... why?
In part II, I thought R3 and R4 are in series and (R1//R2) is in series with R3. Why is (R1//R2) //(R3+R4) incorrect?
