Will a matching impedance network also act as a filter? I'm using a pi network and am wondering if I should also add a filter. I designed the pi network by using the program SimSmith and it consists of a shunt capacitor, series inductor, and another shunt capacitor.
A pi network, as described, is a filter and it can sometimes be used to match impedances. However, a straight impedance matcher is normally only resistive (such as for the termination of cables to prevent reflections at RF).
The pi network will act like a filter and if you are not happy about its performance as a filter then add a filter but, the filter will need to match the impedances you may be seeking to maintain.
\$\begingroup\$ If an impedance matching network includes resistors then part (or even all, as in your example) of the available power is not delivered to the load -which is the purpose of most RF matching networks. \$\endgroup\$– PetrusCommented Apr 4, 2017 at 14:51
They can act as a filter in the sense that the matching network will have a inherent frequency response out of band. This performance is definitely secondary to the impedance matching functionality.
If you do add a filter to the circuit, keep in mind that most impedance matching approaches assume that you're matching to a fixed resistance, even well out of band. This is not what a filter will present as an input / output impedance. You should separate the impedance match with some sort of impedance buffering. The details of this is left to your system design.
The purpose of impedance matching networks is that all the available power is delivered to the load. There are many matching networks that perform this task at a given frequency of operation. Once you depart from it, the frequency dependence of the matching elements (and the frequency dependence of the load) give an overall non-constant frequency response which may be called a "filter": a network whose response depends on the input frequency.
Some matching structures are designed to offer matching and performing an useful filter function, such as a bandpass response. For this, you need a suitable structure and sufficient degrees of freedom in the element values: a two-element matching circuit can only match two requirements (real and imaginary part of impedance). With a three element structure you may be able to achieve a given bandwidth, etc.
