I have an MSP430 waking up every millisecond from a timer interrupt (to do a tiny amount of work, ie increment a counter and check a couple of input pins). It is set up to run at 25MHz. What should I expect as the total power consumption? How would one calculate that from values in the spec sheet?
(The specs for this exact part say 195uA/MHz running from flash and 2.1uA in LPM3, plus "fast wakeup" I think 6us from LPM3)
