I have everything right now, but the output I desire should be 00 00 11 00 00 00 00 10 00 00 00 when the clock is 1(z1z0). Can someone tell me what is wrong with my code? I've checked my Kmap numerous times.
output The JKFFs I should be implementing is: JKFFs
module csm51a_proj3(
input r,
input x1,
input x0,
input clk,
output z0,
output z1
jkff i_jkff
.r(r),
.x1(x1),
.x0(x0),
.clk(clk),
.z0(z0),
.z1(z1)
endmodule
Below is the jkff implementation:
    module jkff(
input clk, r, x1, x0,
output wire z1,z0
reg s0,s1;
initial begin s0<=1'b0; s1<=1'b0; end
assign z0=(x1&&!s0&&s1);
assign z1=(s1&&x0&&(!s0||x1));
wire a1, a2, a3, J1, K1, J0, K0;
assign a1=(x1||s0);
assign J1=(a1&&x0);
assign a2=(x1||!s0);
assign K1=(x0&&a2);
assign a3=(x1||s1);
assign J0=(x0&&!s1);
assign K0=(a3&&x0);
 always @(posedge clk or posedge r)
 begin
    if (r) begin
        s1<=0;
        s0<=0;
        end
    else begin
    case ({J1,K1})
    2'b00: s1<=s1;
    2'b01: s1<=1'b0;
    2'b10: s1<=1'b1;
    2'b11: s1<=~s1;
    endcase
    case ({J0,K0})
    2'b00: s0<=s0;
    2'b01: s0<=1'b0;
    2'b10: s0<=1'b1;
    2'b11: s0<=~s0;
    endcase
end
end
endmodule
Below is the test bench
    module csm51a_proj3_tb(
    reg reset, clk, x1, x0;
    wire z0, z1;
initial begin clk=0; end
always begin #5 clk=~clk; end
    csm51a_proj3 csm51a_proj3
    .r(reset),
    .x1(x1),
    .x0(x0),
    .clk(clk),
    .z0(z0),
    .z1(z1)
    initial begin
    reset=0;x1=1;x0=1;//clk=1;
    #10;
    reset=0;x1=0;x0=1;//clk=1;
    #10;
    #10;
    reset=1;x1=0;x0=0;//clk=1;
    #10;
    #10;
    #10;
    #10;
    #10;
    #10;
    #10;
    #10;
    end
endmodule
    \$\begingroup\$ Module outputs must be connected to something of type 'wire'. You cannot assign the output to a 'reg'. The rule for connecting to a module: in = reg or wire; out = wire. For making a module it is the opposite: input = wire; output = reg or wire \$\endgroup\$ May 30, 2015 at 3:00
  • \$\begingroup\$ You also can't mix blocking and non-blocking assignments in an always block - notice how for the s1 register, the reset statement uses a '<=', but in the case you used a '='. Use one or the other, not both. And in most cases you should use a non-blocking '<='. \$\endgroup\$ May 30, 2015 at 3:05
    \$\begingroup\$ jkff doesn't have a Q pin, and if it did, you can only connect one signal to it. There are also missing inputs to the jkff. I think you want wire a,b, a1,a2,a3,a4; jkff i_jkff(.s0(a), .s1(b), .*); FYI s0 is not assigned and should be. \$\endgroup\$
    – Greg
    May 30, 2015 at 3:22
First of all, when it comes to instantiating and connecting to modules, any output of the module must be connected to something of type 'wire'. You cannot assign the output to a 'reg'.
The rule for connecting to a module is:
inputs can be fed with a 'reg' or 'wire' (includes constants)
outputs must be connected to a 'wire' (or unconnected)
When making a module it is the opposite that is true:
an input can be of type 'wire'
an output can be of type 'reg' or 'wire'
Secondly you cannot mix blocking and non-blocking assignments in an always block. Notice how in the reset clause of the s1 register, you have the statement s1<=0 - this is a non-blocking assignment. But inside the case statement you use a s1=... which is a blocking assignment.
Use one or the other, not both. In most cases you should use a non-blocking '<=' assignment as it means that if you have multiple registers being assigned in the always block they will all get assigned independently of the others. If you use a blocking assignment it means that you may find that extra logic is inserted causing things you don't intend.
For example, take these two codes:
//Code 1
reg a;
reg b;
wire c;
assign c = (a == b);
always @ (posedge clock) begin
    a <= ~a;
    b <= a;
end
//Code 2
reg a;
reg b;
wire c;
    a = ~a;
    b = a;
end
In the first example, 'b' is a pipelined version of 'a'. This means that the value in 'b' will always be the value in 'a' but one clock cycle delayed - essentially the old value of 'a' will be clocked into 'b' on each clock edge. What this means is that the variable 'c' will in this example always be 0.
In the second example, 'b' and 'a' are always the same. The value '~a' is assigned to 'a' on the clock edge, but because the assignment is blocking, it means that the value to be assigned to be should be determined by the synthesiser after it calculation for 'a' has been done. So you end up with the new value that is going to be assigned to 'a' will also be assigned to 'b'. So in this example the variable 'c' will always be 1. (Note: in the synthesized code a and b will still be assigned on the same clock edge, there is no delay, essentially the example is identical to writing b <= ~a;)
Notice how one tiny change can result in completely different behaviour.
Edit:
Now that you've modified the question, most of the above has been corrected. But there are still the things that @Greg rightly noted in the comments section to fix.
You have the issue that you still haven't connected your JK flip flop module up correctly. In your code you instantiate your flip flop as:
jkff i_jkff
.s0(ss0),
.s1(ss1)
But you declare the module as:
module jkff(
    output reg s0,
    output reg s1
Notice how the module declaration has 4 other inputs that you haven't connected in your instantiation. How is your module supposed to do anything if you don't give it any input?
Also, in you JK flip flop module you have logic for the output register s1 - an always block which assigns it a value on each positive clock edge. BUT you haven't got any logic for the output register s0. So why do you expect s0 to do anything at all?
  • \$\begingroup\$ I got it to compile, but I get wrong outputs. Can you tell me what is wrong? \$\endgroup\$
    – Kevin Lee
    May 31, 2015 at 5:33
  • \$\begingroup\$ @KevinLee In your edited question, you still haven't connected up your JK flip flop module correctly - you have to connect up the inputs otherwise how does the logic know what to do?? \$\endgroup\$ May 31, 2015 at 20:05
  • \$\begingroup\$ I did put in inputs and stuff, but it appears that when the machine is first powered on, there is no preset state, so I get an error. How do I do fix this? In jkff, s0 and s1 should be 00 when the machine is first powered on. \$\endgroup\$
    – Kevin Lee
    Jun 1, 2015 at 21:41
  • \$\begingroup\$ @KevinLee In the code you posted above, you haven't connected .clk, .r, .x1 or .x0 in 'mainfile'. Nor have you assigned the output of s0 to anything - in which case anything that relies on s0 will result as don't care. \$\endgroup\$ Jun 1, 2015 at 22:44
  • \$\begingroup\$ I've got it at least working, but my outputs are wrong. Can you tell me what is wrong? My switching expressions are correct. I've checked numerous times. I think that the location of switching expression may affect my output. \$\endgroup\$
    – Kevin Lee
    Jun 2, 2015 at 20:52
