Knowing nothing more than most of the signal traces on a project are 7.5mil and it's a high end audio product, i.e. it's not a high frequency or any 'advanced' application, what would be a safe minimal trace clearance between parallel-running signal traces, assuming it's safe to run the traces under scrutiny in parallel. I'm finishing up a PCB design project. I plan to hand it in to my boss tomorrow. He mentioned that the signal traces could have been set up with a 7.5mil clearance between them. Right now I have it at 12mil, but I want to minimize it as I hear the extra 5mil of clearance will not improve performance of the product in any way and I would like to conserve copper (less pollution, creation cost, I could make the ground and power puddles larger, etc.) I really need to learn EMFT! I like to be able to calculate and model things mathematically when I design, however my level of knowledge is not at the level to where I could go through the design at the schematic level, decipher the relevant info from the datasheets and answer this question on my own. Is there a PCB Design for Dummies? :)
Appreciate any advice. Thanks.
