I'm looking to build my own 12VDC controller for a low voltage electric blanket (specifically, this blanket http://www.amazon.com/gp/product/B0041RQXKE ). An obvious implementation with a microcontroller as a duty cycle timer, relay, and DC-DC converter would be easy enough, but surely the real controllers for these blankets do something more complicated with temperature sensing. How does that work, so I can emulate it?
I know old electric blankets would use a bimetallic strip along the heating current path to adjust duty cycle as a function of ambient temperature. Do modern blankets still just use ambient temperature or do they get temperature feedback from the blanket?
I realize that native 12V electric blankets exist, although I wasn't able to find one that was the full length of a bed or with a full featured controller. I'm also aware that I could use a small inverter to convert to AC then let the blanket's original controller convert back to DC, but I'm not willing to deal with the fan noise or efficiency losses.
    \$\begingroup\$ if the heating wire is 316 stainless steel you could treat it as a thermistor, but if it's nichrome its resistance will not change much at all. \$\endgroup\$ Commented Nov 24, 2015 at 1:32
    \$\begingroup\$ Asking how a specific commercial product works is a hail-mary question... given that it has no documentation of its internals. Why don't you do a teardown and measure its responses etc? \$\endgroup\$ Commented Nov 24, 2015 at 1:41
  • \$\begingroup\$ Unfortunately youtube doesn't help much with teardowns for this type of products. Best I found so far is youtu.be/dfOxSdYgDyM?t=81 \$\endgroup\$ Commented Nov 24, 2015 at 1:48
    \$\begingroup\$ @RespawnedFluff Primarily because it hasn't shipped yet, but I'll certainly do so when it arrives. If the method by which new electric blankets do temperature sensing was common knowledge (to folks who aren't me) then it would save time in reverse engineering. I only mentioned the model because there may be a difference between the regular 120V models and the low voltage DC ones. \$\endgroup\$ Commented Nov 24, 2015 at 1:50
  • \$\begingroup\$ @Jasen I'm not sure what the element wire is made of, but it does appear to be acting as a thermistor. \$\endgroup\$ Commented Nov 26, 2015 at 3:09
Happily, it looks like the controller operates entirely after the ACDC transformer, so I'll probably just replace it with a DCDC converter and not have to deal with making my own controller.
I took the thing apart anyway and have some analysis and photos to share in case anybody is interested in this in the future.
Power supply is rated for 18VDC output at 3.5A (63W)
Power Transformer
Blanket element is just 2 leads. Measures at 4.6-4.7 ohms at 77 degrees F. Measures 4.0-4.2 ohms after the whole blanket was in the freezer for an hour. After running for 15 minutes or so on high (until the blanket felt warm while folded in 4 layers), it measures 5.1-5.2 ohms, so it does look like the resistance is significantly dependent on temperature.
Element resistance seems a little low; as measured (including other resistances in the supply path) it would dissipate 68+ watts, but the supply is only rated for 63. It may be my cheap RadioShack meter having a static offset (overcompensating for resistance internal to the meter?) since the measurements are repeatable and steady. On the other hand, the power should be a little lower (higher element resistance) when it heats up during operation, so the manufacturer may have decided a slight excess while cold was close enough.
On the 120V side, the unit consumed 76 watts (as measured by a Kill-A-Watt meter) when I first plugged it in, but is consuming 65 after warming up. This doesn't say much about power use when cold, as the transformer efficiency is unknown, but does show that it draws under or very close to the rated power when warm.
Lets take a look inside the controller
Top
Bottom
The design uses a common positive rail (direct connection to blanket's positive terminal) - control operates on the negative rail.
Using an 8-bit PIC microcontroller (PIC16F684)
PIC
Element is directly connected to positive rail A mosfet switches on the negative output from right after an inline shunt from negative supply. More or less controlled directly from one the PIC's output pins. P40NF03L - 40A 30V N-channel MOSFET. 0.020 ohm when operating
MOSFET
The shunt (the 3 big 0.22 ohm +-1% resistors in parallel on the bare side of the board) will dissipate 0.3W each at max rated amperage. They're 2W resistors, I guess they didn't want them to get too hot LM2904 Op amp (chip on the left in this photo) looks like it is used at least for voltage sensing (and therefore current sensing) after the shunt.
Current sensing is almost surely used for safety reasons, although this is probably how they do temperature sensing as well.
TS12 - SCR from supply positive to negative, appears to be a crowbar, but there is no inline fuse.
SCR
Probably relying on the power supply or the thin part of trace between the main positive rail and the SCR... the trace burning would only protect part of the circuit though. I'll have to ensure I use a fuse (4A?) inline with my DCDC converter.
This looks like a light sensor (photoresistor)... why?
light sensor
There is a little opening cut in the controller's shell for it to see the outside world. Upon further testing, it immediately and obviously controls the LED intensity that shines through the dial's display to show the power setting. The dynamic range isn't that great (lowest setting is maybe 25% as bright as the highest), and I'm floored that they bothered to put this feature into such a simple product.
Sorry for the mediocre photos, they were taken with a cell phone.
