I have to find the transfer function of the following circuit (AC, sinusoidal), using complex numbers, Kirchoff point rule with potentials or Millman's theorem.
The transfer function is \$\underline{H}=\frac{\underline{i_1}}{\underline{u}}\$ .
Here is what I did for now. Schematic using complex impedances:
Then we have : \$-(V_B-V_A)\frac{1}{Z_L+Z_C}-(V_B-V_A)\frac{1}{Z_C}+(V_C-V_A)\frac{1}{Z_L}+u(t)\times i_1=0\$ ^-- False, check in comments for the right one
But what to do now, how to find i1 and u? Thank you in advance.
