I can make an LED glow very dimly in all 4 following circuits. The voltage source in the circuits is the output of an AC to DC converter fed into a breadboard. Also, one end of the voltage source is always floating, as shown on the schematics.
What is the physics behind this? I understand that there occurs a potential difference between me and positive AND me and negative terminals of my power supply but I don't know how and why this happens. Also I understand that depending of the circuit, my electrical potential becomes:
- Higher than the negative terminal
- Lower than the negative terminal
- Higher than the positive terminal
- Lower than the positive terminal
Since the LED glows in all 4 configurations. How is this happening?
