I am trying to connect my DE0 Nano FPGA to an display by using VGA. The output ports of the DE0 Nano have a voltage of 3.3, but the RGB Signals of the VGA want 0,7 V so I used a voltage divider.
I found this pinout for the VGA: Pin Connection Ive got a simple program that the RGB Signals are constant "1", so that the screen should give me white. The RGB signals are 0,7 V when they are not connected to the screen. When i connect the cable to the screen a short circuit appears, and on RGB I've got 0 V..
Red Signal > Pin 1
Green Signal > Pin 2
Blue Signal > Pin 3
H_Sync Signal > Pin 13
V_Sync Signal > Pin 14
GND Signal > Pin 5
Does anybody have an idea what i am doing wrong?
Ive solved the problem, i made a voltage divider to make sure there is 0,7 Volt on the RGB signals. But i used resistors in the k range, so my current was being limited. This made my voltage go to zero..
