I am asked to find the power of the real current source I1:
For that I would need to know the voltage of I1, and I want to find the Thevenin equivalent for the rest of the circuit. Now in my textbook it says that I can apply this theorem to replace some part of the circuit between "two points" A and B, however here I'm not sure where to put A and B, my assumption was that since I1-R4 are in parallel the Voltage/Potential between them is the same so I can do something like this:
And now just find the Voltage between A and B using nodal analysis (also Rth), are my assumptions correct?
After which $$P_{Ig}=U_{Ig}Ig-\frac{U_{Ig}^2}{R_4}$$
Just remove the current source. Do not remove R4 (If you remove R4 it will distort the result).
Then determine the Thevenin Equvalent of the remaining circuit: get equivalent circuit of voltage source \$V_{Th}\$ with a series resistance \$R_{Th}\$.
The voltage across the current source then is \$V_{CS} = V_{Th}\$ ± 1mA * \$R_{th}\$
(The ambiguity of the ± sign comes from the fact that it is not clear whichg side (A or B) is the GND side of the Thevenin Eq.)
Now you have the voltage across \$V_{CS}\$ and the current through \$I_{CS}\$ (=1mA) the current source to calculate the power.
