6
        ______
A _____|      |________
         ______
B ______|      |_______
Which edge arrives first?
I have two digital pulses that arrive at almost the same time, and I need to determine which pulse arrived first. I need to resolve to ~500ps, i.e. the pulses may arrive 500ps apart and I still need to be able to resolve which one came first. The pulses are the exact same width, they are wide (~10us) relative to the edge timing, and the period of the pulses is about 20ms.
Most of what I've come up with (anything flip-flop-based) doesn't work due to prop delays.
Since what I ultimately want to do is align the pulses, i.e. reduce the delta to 0, I thought about XORing the two pulses (theoretically producing an even shorter pulse the width of the delta) and then minimizing the width of the XOR'd pulse by adjusting the delay of one of the channels. Unfortunately most of the pulse is eaten alive by the rise/fall times of most logic (even PECL is questionable), so it's hard to get a large enough signal to process (peak detect with a diode, R and C and minimize the resulting voltage).
Any other ideas? I'm going to start looking at PLLs next, though I'd rather not if there's something simpler...
  • \$\begingroup\$ I don't have time to compose a full answer at the moment, but my initial thought is to connect the anodes of two Schottky diodes to each signal, and connect the cathodes with a resistor. A positive pulse will appear on the resistor if A comes first, a negative pulse will appear if B comes first, and little voltage will appear if they are equal. (Tada! XOR with near-zero delay!) I don't have enough information to help you adjust the delay. \$\endgroup\$ Commented Nov 11, 2011 at 2:01
  • \$\begingroup\$ I love the concept of a 2-diode fast XOR, but I don't quite follow you. This positive and negative pulse are with respect to what potential? (I already know how to adjust the delays - just need to know which direction to adjust them in.) \$\endgroup\$ Commented Nov 11, 2011 at 16:26
  • \$\begingroup\$ Sorry - That was an initial thought, not a solution. I really ought to avoid posting partially-thought-out answers as comments. I hadn't sufficiently considered the return path for the current though the resistor; you'd need to connect the output to ground through a resistance, and you'd still need the differential amplifier as all the other solutions - The diodes didn't gain anything. \$\endgroup\$ Commented Nov 11, 2011 at 16:51
  • \$\begingroup\$ Seems like your original idea of a flip-flop based solution would be good. Can you elaborate on the problem you had with prop delays? \$\endgroup\$ Commented Jun 29, 2015 at 19:58
4 Answers 4
Can you put the two into a differential amplifier? Both low or high would be 0 V out. One high before the other is a positive pulse, the opposite situation is a negative pulse. Not sure if that would respond fast enough, or if there's any delay from one input to the other.
  • \$\begingroup\$ That's a good idea, except for the offset error of the differential amp. If it had a lot of gain, the offset multiplied by the gain would make the offset saturate high or low before any of the pulses came. If it didn't have a lot of gain, I don't think the amplifier would slew very far before the second pulse arrived. Will think about it, though... \$\endgroup\$ Commented Nov 11, 2011 at 16:34
My suggestion would be something like this.
The first pulse that arrives pulls the Drain of the FET low, and on the same time blocks input from the second pulse. So the FET's Drain that goes low (during the 10uS pulse high), is the one at which the pulse arrived first.
At those pulse speeds, you are probably going to need some matching on the Gate pin, to avoid the Gate-capaticance having too much effect and further avoiding reflection.
EDIT: there needs to be schottky diodes on the wires between gate and drain, to block the bias from flowing from VCC to gate.
Circuit
  • \$\begingroup\$ I really like this concept! Thought it was a latch, but is actually a pulse, which might be good enough. Initially both inputs are high, so both outputs (drains) are low, and the schottkys are inserted to keep the high inputs from pulling up on the drains. Input A goes low, Keeping output B low, so output A starts rising. But as soon as In B goes low, it yanks output A back down as well. So you will get a short positive pulse on A, and no pulse on B. Gonna see if I can find a way to make it latching... \$\endgroup\$ Commented Nov 11, 2011 at 19:18
(1) COMPARATOR BASED
The Analog Devices "Ultrafast SiGe Voltage Comparators" ADCMP580/ADCMP581/ADCMP582 look suitably fast enough for the task - datasheet here
Rise and fall times !!!
Fast enough?
With the Analog Devices "Ultrafast 3.3 V/5 V Single-Supply SiGe Comparators ADCMP572/ADCMP573" - datasheet here close behind.
Neither especially cheap :-( - over $20 each in small quantities at Digikey,
The '580 shoes an application with a tolerably good eye diagram at 7.5 Gbps!
'580 - Some specifications:
  • 180 ps propagation delay
    25 ps overdrive and slew rate dispersion
    8 GHz equivalent input rise time bandwidth
    100 ps minimum pulse width
    37 ps typical output rise/fall
    10 ps deterministic jitter (DJ)
    200 fs random jitter (RJ)
    and
    −2 V to +3 V input range with +5 V/−5 V supplies
    On-chip terminations at both input pins
    Resistor-programmable hysteresis
    Differential latch control
    Power supply rejection > 70 dB
(2) GATE BASED
Implementing X NOT.Y gives you a signal that:
  • If X goes high first
    Goes high an AND delay after X goes high and goes low again an AND and an INV delay after Y goes high.
  • If Y goes high first
    Goes high and AND and an INV delay afer Y and low again an AND delay after X goes high.
This assymmetry is "not nice" and MAY give confusing results under some timings but allows you to use basic gate delays rather than flipflops.
By inverting to the equivalent NOT.X Y you seem to eliminate the transient false state. (Needs more thought).
  • \$\begingroup\$ The ADCMP572 does look fast enough - I may end up going that route. \$\endgroup\$ Commented Nov 11, 2011 at 20:55
I'm not exactly sure what you are trying to do, but measuring charge time on a capacitor might work.
For example you have a current source which charges the (very stable, e.g slver mica or similar) capacitor up. When a pulse arrives a second stronger current sink discharges the capacitor very quickly, and then you measure the time taken to charge up again. The current ratios will depend on the counter clock rate and the resolution you want to achieve. Say you have a 100MHz clock and a 1000:1 ratio, then the resolution will be 10ns/1000 = 10ps.
You would have to adapt it to meet your requirements, e.g. arrange it so the input is triggered when one line is at 1 and the other 0 (maybe on the rsisng edge too)
Here is a diagram (the signal input switches I2 on the left):
Charge Time Measure
There are also ICs that can probably do the job, such as the TDC series from Acam. I would expect them to be quite expensive though.
