Here's how to measure the inductance:
If you resonate the loudspeaker's voice coil with a known capacitance, then the reactances of the capacitor and the voice will cancel at resonance and all you'll be left with will be the resistance of the voice coil at that frequency.
Knowing the capacitance and the resonant frequency of the capacitor and the voice coil's inductance, the capacitive reactance can be calculated from:
$$ X_c = \frac{1}{2 \pi f C} $$
Then, since \$ X_L = X_C \$ at resonance, we can calculate the value of the voice coil's inductance by substituting the value of \$X_C\$ for \$X_L\$, like this:
$$ L = \frac{X_L}{2\pi f} = \frac{X_C}{2\pi f} $$
I tried it using this rig, where the generator's output impedance is 50 ohms, resistive, R1 is 10 ohms (just to increase the generator's output impedance a little), C1 is a capacitor decade box, Ls is the loudspeaker's inductance, Rs is the loudspeaker's resistance and "V" and "f" are an analog scope and a frequency counter, respectively.
To use it, I set C1 to 500 nF and adjusted the generator for a dip in the scope's response, recorded the frequency and capacitance of C1, then repeated the procedure for 100nF and 1\$ \mu F\$.
After the arithmetic, here are my results:
C1 f Xc L
nF kHz ohms uH
100 50.4 31 100
500 20.6 15.5 120
1000 14.6 11 120
Now for the power...
In order to determine how much power is being dissipated by the voice coil, with a given voltage across it, we can write:
$$ P = \frac{E^2}{Z} $$
Where P is the power in watts, E is the RMS voltage across the coil, and Z is the impedance of the series RL comprising the coil.
In order to determine the impedance of the coil we can write:
$$ Z = \sqrt (R^2 + X_L^2) $$
The measured resistance of the coil at DC was 8.1 ohms, and plugging that into the formula along with the coil's calculated reactance at 14.6kHz gives us:
$$ Z = \sqrt (8.1\Omega^2 + 11\Omega^2) \approx 13.7 \text{ ohms} $$
The loudspeaker I used to get the data is a Panasonic EAS6P22S which is rated for 500 milliwatts, so to find out what voltage we need to drive it to full power (at 14.6 kHz) we can rearrange:
to
$$ E = \sqrt PZ $$
and solve:
$$ E= \sqrt (0.5W \times 13.7\Omega) \approx 2.6VRMS $$
