I'm trying to induce Quality factor of RLC circuit.
In series, I did it with Frequency responce $$ H(s) = R/(R+sL+1/sC) = (something)/(s^2+2sw_0\zeta+w_0^2)$$ And $$Q=1/2\zeta$$ But I can't find how to induce it in parallel.
  • \$\begingroup\$ Multiply numerator and denominator by sC. \$\endgroup\$
    – The Photon
    Commented Apr 14, 2016 at 14:58
  • \$\begingroup\$ Actually that equation came from RLC series circuit, and I found Quality factor with $$Q=Root(L/C)*1/R$$. I'm trying to find parallel one. \$\endgroup\$
    – user325050
    Commented Apr 14, 2016 at 15:07
  • \$\begingroup\$ By the way, ee.se uses \$ to start and end inline math. \$\endgroup\$
    – The Photon
    Commented Apr 14, 2016 at 15:09
  • \$\begingroup\$ I tried to use root or divide symbol but failed... I used $$. Do you know how to use them? \$\endgroup\$
    – user325050
    Commented Apr 14, 2016 at 15:11
  • \$\begingroup\$ You can write \$\sqrt{L/R}\$, for example, to get a square root symbol (\$\sqrt{L/R}\$). \$\endgroup\$
    – The Photon
    Commented Apr 14, 2016 at 16:19
If you did the math you would find that the \$2\zeta\omega_0\$ term comes out as \$\frac{1}{CR}\$.
Knowing that \$\omega_0 = \frac{1}{\sqrt{LC}}\$ you can compute zeta as equal to \$\frac{1}{2R}\sqrt{\frac{L}{C}}\$.
You know how to turn zeta into Q so no need to restate that.
Explanation
You have to imagine driving the parallel RLC from a current source because a current source has infinite output impedance and therefore its impedance doesn't alter the circuit values. Next you turn the current source and the parallel resistance of the RLC into a voltage source and series resistor. Again, I stress no impedances or math is harmed in this re-arrangement!
You then can make a sensible TF of the new circuit: -
\$H(s) = \dfrac{X_L||X_C}{R + X_L||X_C}\$
Where \$X_L||X_C = \dfrac{\frac{sL}{sC}}{sL + 1/sC} = \dfrac{sL}{1+s^2LC}\$
Stuff it in the formula and you get: -
\$H(s) = \dfrac{sL}{R + s^2LCR + sL}\$
Next, divide through by LCR to get: -
\$H(s) = \dfrac{\frac{s}{CR}}{s^2 + \frac{s}{CR} + \frac{1}{LC}}\$
Now it's in standard form for recognizing that \$\frac{1}{CR} = 2\zeta\omega_0\$. Continue to find zeta as per my original answer.
  • \$\begingroup\$ That one was about series RLC circuit. I'm trying to find parallel quality factor. \$\endgroup\$
    – user325050
    Commented Apr 14, 2016 at 15:13
  • \$\begingroup\$ My formula IS zeta for a parallel RLC. Do the algebra to simply convert to Q. \$\endgroup\$
    Commented Apr 14, 2016 at 16:34
  • \$\begingroup\$ Sorry, I misunderstood your answer. Your formula is right. How can I induce that formula? \$\endgroup\$
    – user325050
    Commented Apr 14, 2016 at 16:38
  • \$\begingroup\$ I'll add explanation to my answer. Give me a few minutes.... \$\endgroup\$
    Commented Apr 14, 2016 at 16:45
  • \$\begingroup\$ I'll wait for you. Thx \$\endgroup\$
    – user325050
    Commented Apr 14, 2016 at 17:04
How did you derive the transfer function for the series circuit? Answer: Complex voltage divider. Why didn`t you try this method also for the parallel combination? Then, if you manipulate the resulting function with the aim to have again a quadratic polynominal in the denominator you can identify the wanted parameter.
  • \$\begingroup\$ Actually I'm not sure how to make transfer function in parallel RLC circuit. I did it in series $$H(s) = (I*V_R)/(I*V_s)$$ because current is same in series. But how should I do in parallel? \$\endgroup\$
    – user325050
    Commented Apr 14, 2016 at 15:05
  • \$\begingroup\$ I am afraid, you have a wrong circuit arrangement in mind. I suppose, you speak about voltage-in and voltage-out, correct? So you need a complex voltage divider. \$\endgroup\$
    – LvW
    Commented Apr 14, 2016 at 15:45
  • \$\begingroup\$ I thought that H(s) is ratio of voltage out and voltage in. Is that incorrect? \$\endgroup\$
    – user325050
    Commented Apr 14, 2016 at 15:47
  • \$\begingroup\$ Yes - that is the definition. \$\endgroup\$
    – LvW
    Commented Apr 14, 2016 at 16:10
  • \$\begingroup\$ But in parallel, voltage is same in R, L, C. Then H(s) should be 1? Or parallel RLC circuit use different definition? \$\endgroup\$
    – user325050
    Commented Apr 14, 2016 at 16:16
