I've got a circuit diagram I'm working from, this one:
And I'm currently trying to breadboard it, as seen here:
I've been trying to search google on how to wire a Relay, and am not yielding any viable results. I've got a omron 5VDC with 5 pins, 2 on the bottom, 3 on the top.
I think I've figured out that the bottom 2 pins are for power, and the top 3 are for output, in some way. :S I'm going to be connecting the output of the relay to an AND gate to test if a switch is on, and act if both inputs are ON.
Two questions? How do I wire up the relay? and Is the circuit so far matching the diagram? (if you can't tell from the instagram image, forget this question!)
ALSO: I did change it slightly, there is no variable resistor, instead there's an 'average' 100Ohm resistor.
Thank you very much! Cheers, John
