I am attempting to deliver 9V @ 1.1A to a PCB circuit design using an L7809CV voltage regulator which is rated for 1.5A max.
Using a power supply, I can deliver the required current and voltage to my PCB (9V/1.1A) and all is well.
Once I turn up the voltage to ~12-14V (emulating an automotive application) and feed it into the L7809, the regulator will output 9V as expected with NO LOAD on the device. Once the load is applied, the device will only deliver 6.9V/0.1A, well below what is expected.
The device does get hot to the touched during extended use, but I would expect the correct current/voltage to (9V/1.1A) to be delivered when the device is cold. Is this not true?
Datasheet for voltage regulator: http://www.mouser.com/ds/2/389/CD00000444-249828.pdf
