I struggle yet another day with very simple problem (circuit). This challenge seems to be very common, but nowhere I can find a complete solution:
I have a heavy load (12v / 1 Ohm peltier = 12A max) which I need to drive using microcontroller (5v Arduino to be specific).
I was able to get an IRFZ44N N-channel power MOSFET, which is rated 49A Vds so hopefully can handle that load. The thing is that its Vgs = 10V (the voltage to turn it fully on).
Here is the circuit I came up with until now, based on 2-stage voltage level shifter (as suggested here):
Simulation shows phase shift between input vin and vdrain anyway, even if there is no phase shift between vin and vgate (which is very mysterious for a noob like me):
Can you please help me understand this or help me coming up with a complete solution? I did spend lots of time trying to Google it and nowhere I can find one without inverting PWN phase (even here at stack-exchange).
And this must be extremely simple right?
In case you ask: I have my reasons to keep it non-inverted (long story short - I do not want the situation that load is on when micro-controller is off as they have separate power supplies). Even thou - I still want to understand the problem and find a solution.
    \$\begingroup\$ if Vgate is HIGH (turn ON) then Vdrain must go LOW so there is no problem. For Vdrain to go HIGH you have to turn the MOSFET off \$\endgroup\$ Commented May 15, 2016 at 21:07
If you want the load to be off when the micro is not powered, the polarity from the driving signal to the output plays no role. When the micro is turned off, its outputs are high impedance, i.e. they act like tiny capacitors with one terminal to ground. Any tiny, little noise can charge these caps, so the voltage on the pins can pretty much assume any value.
You can solve this problem in many ways. Since you use the level shifter I will assume the arduino pins are not 12V tolerant.
Here's your schematic:
That's actually pretty near to what you have. I am not really sure of why you had all these resistors spread around, anyway let's see what happens in three cases.
vin = 5V
Q3 is on, Q2 is off, mos gate is tied high via R4, load is on
vin = 0V
Q3 is off, Q2 is on, mos gate is tied low, load is off
vin = hiz
this means vin is disconnected. R6 pulls the first bjt base low, turning it off, Q2 is on, load is off.
Please note that this circuit does not use the 5V rail, so if the 5V rail is removed the load is switched off.
If you can be sure that the 5V will always be present when the 12V is present, then you can probably save one transistor.
  • \$\begingroup\$ Unfortunately V at drain is still inverted (even if Vgate and Vin are in phase). I have no idea what is going on \$\endgroup\$
    – Lukasz
    Commented May 15, 2016 at 20:59
  • \$\begingroup\$ What do you mean with inverted? And why do you care? \$\endgroup\$ Commented May 15, 2016 at 21:04
    \$\begingroup\$ When the mos is turned on, i.e. its gate is high, the drain and the source get connected, since the drain is at 0V the source goes (almost) to 0V too. \$\endgroup\$ Commented May 15, 2016 at 21:10
    \$\begingroup\$ Your circuit was almost ok. It was not safe with the micro off. And please if you need infos on a resistor use its number, i.e. R1, R2 etc. \$\endgroup\$ Commented May 15, 2016 at 21:18
    \$\begingroup\$ @Lukasz - I also recommend reducing R5 to 1k. As shown, the gate voltage is not guaranteed to drop low enough to fully turn off the FET. R4 (200 ohms) will need about 60 mA, but the base current provided by 10k is only about 1 mA, and a gain of 60 is more than you should require under these circumstances. \$\endgroup\$ Commented May 15, 2016 at 23:29
While Vladimir Cravero's circuit will do what you want, I think you misunderstood the operation of both his circuit and your original. You objected that a low input produces a high drain voltage, and called this a phase shift. While it's true that this is a phase shift (technically, a phase inversion), you missed the point that the load resistance is tied to V+, not ground. A high drain voltage implies zero current through the resistor, and this is what you wanted.
  • \$\begingroup\$ I got that - basically it simply means that if there is any other voltage than 0V at the Drain then MOSFET is not on or not fully on (has some resistance). So actually it could also serve as means to measure if it is fully on - lower the voltage = lower Drain->Source resisntace right? \$\endgroup\$
    – Lukasz
    Commented May 15, 2016 at 22:51
