I am working on a board design which includes an ADC and a DAC. The board attaches to the headers of the Mojo V3 Spartan 6 FPGA Dev Board. The ADC has to pick up a quiet signal at the same time as the DAC is emitting a signal. My goal is to reduce coupling between the ADC signal path and the DAC signal path as best as I reasonably can, and also to isolate the ADC / signal conditioner from noise generated by the FPGA.
The ADC and DAC are running at 200MSPS, with clock and data connections ported through the dev board header. I will be getting rid of the header later by putting the FPGA and ADC/DAC on a single board, so for now am ignoring problems with coupling between header pins.
I am following the recommendations of the answer on this thread on grounding. I have read the references provided by this answer, and other references (see below) on grounding, and am trying to implement them.
- Ott - Partitioning and Layout of Mixed Signal PCB
- Ott - Ch. 3, Grounding
- Zumbahlen - Staying Well Grounded
- E2V App Note - Mixed Signal PCBs
- Clayton Paul - Electromagnetic Compatibility (Comprehensive Kick-Ass EMI/EMC Book)
My plan is to make a 4 layer board, with stack-up:
- Signal (with ground pour around signal lines)
- Ground (sourced by header pins from FPGA board)
- 5V (sourced by header pin from FPGA board)
- Ground
I am planning to take advantage of ground plane and power plane partitioning between the DAC and ADC. I would also like to add a RF shield can (something like this), and this is where I am having trouble deciding what I should do.
Option 1 is to leave the ADC / DAC outside of the RF shield can. See diagram below.
Advantages: Digital lines that connect ADC to FPGA do not penetrate the RF shield. Clock line also does not penetrate the RF shield. RF shield aperture is small, since it only has to allow a signal trace, a power trace, and a reference voltage trace.
Disadvantages: ADC chip is exposed to radiated coupling from FPGA / DAC / external sources. Analog signal trace itself is exposed when leaving the RF shield.
Option 2 is to include the ADC / DAC inside of the RF shield can. See diagram below.
Advantages: ADC chip is shielded from radiated sources, possibly coming from external sources or the DAC / FPGA.
Disadvantages: Shield aperture is larger since it has to accommodate 8-14 signal lines, a clock line, and a power line from the regulator. Also, digital lines penetrate the shield aperture, and since they are switching at up to 200MHz, noise may couple to the amps.
Which is the better option? If you have other advice on improving this design from an EMI/EMC standpoint, that would be appreciated.
Thanks in advance!
