Is it possible to indicate countersunk holes in the gerber files?
Currently if a board has countersunk holes, I need to indicate this in a separate drawing and send it along to the manufacturer with the gerbers.
I'm trying to figure out if a countersunk hole can be indicated through the layout software (Mentor PADS in my case) when I produce the files, or if it is even possible with the gerber format.
    \$\begingroup\$ I think that would have to be called out in the drill file, which is generally sent to the manufacturer with the gerber files. \$\endgroup\$
    – DerStrom8
    Nov 8, 2016 at 20:17
  • \$\begingroup\$ In Gerbers... probably. But you might find it easier to confer with your manufacturer by simply discussing it. No two manufacturers will be entirely happy with any set of odd requirements like this. \$\endgroup\$
    – user98663
    Nov 8, 2016 at 20:20
    \$\begingroup\$ I thought all Gerber was all. XY and no Z \$\endgroup\$ Nov 8, 2016 at 20:21
    \$\begingroup\$ I suggest producing a separate drill file for the countersunk holes, but definitely talk to the supplier. I've been through this recently and they dealt with it, but I was paying >$1K in setup costs.. \$\endgroup\$ Nov 8, 2016 at 20:35
    \$\begingroup\$ I'd include a CAD drawing for something like this. (You may want to specify the angle and perhaps the depth of the counter sink.) And as everyone else says, talk to the board house. \$\endgroup\$ Nov 8, 2016 at 21:15
You should talk to your board house and discuss with them what data they need and what you can deliver for countersunk holes.
If they get a separate drawing, they have to digitize it and edit the needed NC drill files manually, but this takes time and money.
A Gerber file is data for photoplotters, but not for NC drill machines. The board house may transform a Gerber file into the needed NC drill file, but this is a manual process using their CAM CAD system and will take some time again.
A separate NC drill file for the countersunk holes only will be the best data for them, but you should discuss the details with them.
But you should be aware that countersunk holes will require additional drill jobs for the PCB, especially if both sides are countersunked. Drilling two or three boards together in a stack as usual is not possible for the countersunks, each board must be drilled separately. If you want to reduce costs, try to avoid countersunks if possible.
  • \$\begingroup\$ Definitely this is not a features supported by NC drill nor Gerbers. The only solution is talking to the PCB maker and agreeing with them how to proceed. \$\endgroup\$ Nov 9, 2016 at 15:23
Understand that a Gerber file is not a manufacturing file. It is not a CNC file. It is not a PCB file. It is just a set of measurements in a standard format, that the PCB house employees will use in the process of creating their CNC files.
So yes, you can put any form of garbage in your "Gerber" files, and if you carefully explain what you want it to mean, your PCB house may be able to work out what you want the measurements to mean. Or not. It will make it more difficult for them, and they may get it wrong, and they certainly won't like you.
Gerber files are 2D + layers + apertures, and in the past, when people had no other way of specifying what they wanted, they sometimes agreed that certain "apertures" or certain "layers" would have special meaning. You will sometimes see references to that, (like this posting), where people are saying: DO NOT DO THAT. THAT IS THE PAST. IT IS NOT HELPFUL.
