I am trying to print pdf of negative artwok in the altium. I am adding full fill on the board different layer. Then change layer color( make black and white ) through Page Setup>Advanced>Preferences. But I cannot color the holes. Some old altium versions have pad hole color and via hole color but I am using Altium Designer 16, where I am unable to find the options.
Question: how to enable the color options for pad holes in Altium?
I trying to make negative artwork pdf. Here my result. enter image description here
I want to make black holes but it's grey.
  • \$\begingroup\$ Why bother making the gray holes black? They're just going to be drilled out anyway, it doesn't matter if they have copper on them or not. \$\endgroup\$
    – DerStrom8
    Jan 10, 2017 at 13:05
    \$\begingroup\$ @DerStrom8 - OP said they're trying to make a PDF, I think this is only about creating a visual... \$\endgroup\$
    – Bort
    Jan 10, 2017 at 14:18
  • \$\begingroup\$ @Bort Ah, I see \$\endgroup\$
    – DerStrom8
    Jan 10, 2017 at 16:27
  • \$\begingroup\$ @DerStrom8 if holes is not black, hole's area will be copper. Its create a problem when try to drill holes. \$\endgroup\$
    – MSB
    Jan 11, 2017 at 8:42
  • \$\begingroup\$ @MSB You mean your drill bit can't even drill through a thin layer of copper? Sounds like you need a better drill bit. Anyway, the negative artwork you are showing won't work for a standard etching process -- The parts you want to KEEP should be black, not white. If you invert the colors then you can always touch it up with a black Sharpie (permanent marker) \$\endgroup\$
    – DerStrom8
    Jan 11, 2017 at 11:11
I don't really understand what you're trying to do and why you want to change their color, but the settings are right in the View Configurations dialog.
You can open this dialog by clicking the colored box next to the "LS" button at the bottom left of the PCB editor.
Easiest way: right click on the corresponding Fabrication Output -> Page Setup -> Color Set -> Mono
