I am looking into a electric vehicle charging system and using a cell that can charge at 1.6 A and a voltage of 4.2 V. Therefore I believe the max power I can expose this cell to while charging is:
P = IV = 1.6 * 4.2 = 6.72 Watts
Would I be correct in thinking that if I were to connect 90 cells in parallel then I could expose this system to:
6.72 * 90 = 605 Watts ?
Would it also be the case that if I connected two of these set of 90 parallel together by a series connection could I expose with system to:
605 * 2 = 1210 Watts ?
  • \$\begingroup\$ Maybe change your point of view a little. Thinking about power consumption may get you further. You almost never "expose a system to power X", but you provide some power source capable of supplying X Watts, and the system consumes as much as it needs at any given point in time. \$\endgroup\$
    – JimmyB
    Commented Mar 19, 2017 at 21:15
Theoretically it's correct but, probably you are talking about li-ion cells. Please note that algorithm of charging for li-ion cells it's diffrent: firstly it's charging at constant current (1-1.6A per cell) and after current is decreasing it's charged with constant voltage (4.2-4.4V per cell) so charging power is variable during this process.
  • \$\begingroup\$ Thanks for that. At the moment I am just looking into the fundamentals but that is very useful to consider. However in general am I correct in saying that the more cells I connect, the more energy I can supply them in charging no matter the cell configuration? \$\endgroup\$ Commented Mar 19, 2017 at 19:03
  • \$\begingroup\$ Yes, it's correct. \$\endgroup\$
    – Fasset
    Commented Mar 19, 2017 at 19:14
