I have found this problem in my textbook.
The system has 3 inputs. The first two, A and B, represent a number in the range 0 to 2 (3 is not used). The third input, C represents a second number in the range 0 to 1. The output, f, is to be 1 if and only if the two numbers equal to each other.
(1) Create the truth table of the system.
(2) Create the k-maps of the system
(3) Get the express f(A, B, C) in minimum SOP form.
(4) Get the express f(A, B, C) in minimum POS form.
I have tried this way:
c A B f
0 0 0 1
0 0 1 0
0 1 0 0
0 1 1 x
1 0 0 0
1 0 1 0
1 1 0 0
1 1 1 x
As f=1 when AB == C .
What does it mean by "The output, f, is to be 1 if and only if the two numbers equal to each other." ? What will be the truth table?
  • \$\begingroup\$ It means that if AB == C then f=1. Otherwise it is 0. What is not clear? \$\endgroup\$
    – Eugene Sh.
    Commented Mar 24, 2017 at 17:42
    \$\begingroup\$ LOL could hey have written that any more confusing... \$\endgroup\$
    – Trevor_G
    Commented Mar 24, 2017 at 17:43
    \$\begingroup\$ @Trevor Indeed that is very confusing. I'm still stuck at the part that says "range 0 to 2 (3 is not used)"... So does that mean you only have 00, 01, 10, and you take out 11 in terms of binary for A and B \$\endgroup\$
    – 12Lappie
    Commented Mar 24, 2017 at 17:45
    \$\begingroup\$ It's one of those questions where you have to start out your answer with "ASSUMING A is Binary Bit 1, and B is Binary Bit 0, and C is a single Binary bit... THEN..." \$\endgroup\$
    – Trevor_G
    Commented Mar 24, 2017 at 17:49
    \$\begingroup\$ @Trevor Which is perfectly legit for self-learning. \$\endgroup\$
    – Eugene Sh.
    Commented Mar 24, 2017 at 17:50
All that means is that AB == C, then f=1. So if AB=1 & C=1, f=1. Same thing happens if AB=0 & C=0, f=1.
So from the question, I gathered that 0 to 2 means that you have A and B in terms of Binary as 00, 01, 10, and 11 is a don't care. With that being said, the truth table would look as follows:
  • AB | C | f
  • 00 | 0 | 1
  • 01 | 0 | 0
  • 10 | 0 | 0
  • 11 | 0 | X
  • 00 | 1 | 0
  • 01 | 1 | 1
  • 10 | 1 | 0
  • 11 | 1 | X
You can very easily extract the K-maps parameter from the truth table as it is essentially the same thing.
  • \$\begingroup\$ I'd forgotten all about k-maps.. Did then at the U... never used them since. \$\endgroup\$
    – Trevor_G
    Commented Mar 24, 2017 at 18:08
  • \$\begingroup\$ @Trevor You want me to include it in there as well? \$\endgroup\$
    – 12Lappie
    Commented Mar 24, 2017 at 18:11
  • \$\begingroup\$ Yes it will be very helpful \$\endgroup\$
    – Leolime
    Commented Mar 24, 2017 at 18:12
    \$\begingroup\$ The person asking the question wants the answer but I think you have all you need in the truth table. K-maps are simply truth tables reorganized \$\endgroup\$
    – 12Lappie
    Commented Mar 24, 2017 at 18:13
    \$\begingroup\$ Oh that's what I was doing all these time... thanks a lot \$\endgroup\$
    – Leolime
    Commented Mar 24, 2017 at 18:31
