I am driving green LED in series with a boost converter and unfortunately my input voltage (24VDC) turns my LED string on slightly even when my manually controlled boost converter is not boosting the voltage. I'm thinking that adding 4 diodes in series with my LED string will be enough to increase the forward voltage so it doesn't turn on until I begin to increase my boost converter voltage past 30V. I'd also like to turn a PFET on so that I can bypass the 4 diodes once I begin increasing the voltage above 24. Any ideas on how to wire the PFET so that when VIN goes above 30VDC, the bypass PFET turns on?
Or any other ideas on how to prevent my LED string from turning on when I'm at 24V?
Thanks in advance!
